Front camber adjustment
I was hoping to get input/experience with these two products:
http://www.spcalignment.com/index.php?o ... &pid=67320
vs.
http://www.spcalignment.com/index.php?o ... &pid=84955
I had the 67320 kit on my ef, and they pushed the upper controll arm up so much it would hit the inner fender on moderate bumps.
I kind of get the feeling the 84955 might be tougher to adjust.
vs.
My favorite one was "Skunk2 Front Pro Series Camber Kit 88-91 Civic" cost $ but was worth it to me.
I would say its trial and error, hit a salvage yard or ebay get a used set for cheap just to try some.
an example i had done, after trying 4 different coil over setups new, used and driving everyone of my buddies cars i ended up liking cheap ebay coil overs "40$ i think" with oem GSR shocks on my eg hatch and it was not because it was cheap "it fit my driving, and handled better in my opinion"
Agree with silvertoe the Skunk2 is a good choice. However I am one of those camber kits are useless guys.
^^^ camber kits are useless guy ^^^^
Im sure they would slip nothing is perfect, mine never did tho. What type of uses are you trying to get out of them? race, DD, DD with track on the weekend?
Heh. The first one, poor design. Not only does it change the oem geometry but also defeats the purpose of even having a camber kit. Camber kits are generally designed for lowered vehicles, take a look at that product. Its a good 3/4+ inch taller than a factory joint, hense moving your upper control arm even closer to shock tower. If you are lowered with this product I would bet it will slap the shock tower even on the slightest bump.
Second link. These are just notorious for breaking and moving. These are the type of camber kit every crap tire shop tries to sell you.
It really boils down to what you are trying to accomplish, why do you think you need a camber kit?
Toe kills tires, not camber.
Edit, I missed this I assume that is the top one. Pretty much what I figured
