What is the Shortest Oem Strut?
I'm looking to lower the wagon over OEM parts.
What is the shortest OEM honda/acura Strut? Are the Crx's shorter than the wagon?
Right now I just have Skunk 2 Coilovers on it, and it gets perfectly low in the rear, but its about 1.5"s too high up front, and its bottomed out on the strut.
What would be the best struts to throw on it?
you need to use the civic top hat but it all bolts right up. even the forks/wishbones fit.
most people run into problems in the rear on the wagon, not the front. As it is identical to any other EF civic.
simplest solution is to do what people call "flipping their coilover sleeve" because the top is threaded all the way, whereas the bottom usually have any threads. after that you can also remove one or both of the height adjusting locking collars.
if you have any questions shoot me a PM.
Right now I'm sitting on mudflaps on the rear. And i haven't Cut the cups off the struts yet.
But with the front I'm bottomed out on the strut body.
I'm making some top hats right now, to give me a little more stroke. And I made me a set of drop forks that I haven't put on yet. So I'm thinking between the two, I will get low enough.
But if not, then it time to get lower/shorter struts.
This is how low i want to be! Dont have the money for the wheels, but someday...
http://www.stancenation.com/2011/01/03/ ... es-part-1/
SOOOOO SICK!!!!!!
Front Struts (measured from top of fork to top of strut body):
85-89 Accord - 8.125"
88-89 Prelude - 8.125"
89-91 Civic - 9.5"
90-93 Integra - 9.5"
Rear Struts (measured from center of bolt to top of strut body):
89-91 Civic - 13.25"
92-95 Civic - 13.25"
90-93 Integra - over 14" - for some reason I didn't write it down right
85-89 Accord - 15.375"
88-89 Prelude - 16.5"
96-00 Civic - 12.875"
So the verdict is that the Accord front struts are the shortest and the ek civic rear struts are the shortest but need modification to fit.
I just installed a set of both on my wagon with tophats. Rides great. I recommend not going over a 1" tophat on the front if you use the accord struts.
Any questions PM me.
If the accord frt struts are a 1 3/8" shorter.Why are you using tophats?Unless you're going real looow.
Thanks.
another question: when running accord front struts is it a MUST to still run extended top hats?
The "bottoming out" effect occurs when you run out of space between the top of the strut body and the top hat mounting location. If you were to lower the spring perch, this distance would decrease. If you raised the perch, this distance increases.
I'm not sure what the previous poster is getting at with changing the perch location, this will not increase the available amount of travel before bottoming out occurs.
Pic below is stock for stock of the rear struts before any modification:
Pic below is after cutting the eyelet off and welding on a fork from a blown da teg rear strut:
Below is a picture of the stock strut with no spring installed. I wanted to see how far the suspension would go down before the tire bottomed out in the wheel well. The stock strut goes through the frame by about a half inch. This is why my car kept bottoming out in the back easily.
This is a picture of as low as the wagon can go on 205/50-15's:
