new here RACEPAK'S B16 WAGON BUILD....
hey guys,
this is my first post here, i was redirected by rbwdriven from HT.
so i just got myself a 2x4 89' civic wagon its the only wagon in my contry :)
it dosnt have any major rust on it, except for some surface rust on the outer shell.
its original engine was a d15b2 and it was replaced to a jdm ZC
i also have a B16A engine with a S1 cable tranny from a SI-R that i had sitting for a long time that i want to swap into the wagon,
the engine is gonna be rebuilt with all new parts with slightly higher compression and new cams.
-the car needs some body work and paint and i need to order some parts from the us that i cant find here in my country.
hood WILL a 4dr ef hood or headlights fit to the wagon ? (sorry for the dumb q)
door and ignition switches (since the last owner lost the keys i had to break into the car to tow it)
again, are 4dr ef switches will work?
will 4dr ef brake lines fit the wagon?
axles? which axles do i need?
i will upload more pics of the engine later.
where can i get that plastic mold?
look, they made a pvc window :S
thanks
  • NZ-DB8RNZ-DB8R Moderator
    There are answers to all your questions (re:sedan hood, axles atc) already on the forum. You just need to search ;)
    Plans sound good though, Bseries in a Wagon is fun. I have B18c with S1 gearbox in mine
    Looks good, give her a good cleaning and you'll be amazed and welcome. There is alotta good info here.
  • racepakracepak Band Wagon
    thanks guys,
    iv been browsing the form and i think i found some of the answers i was looking for, but there are still some things that i'm not sure of,
    are the rotots and pads + rear drums and shoes the same as a 91 sedan?
    can i use door lock switches and ignition switch off a 91 sedan?
    and the rear hatch lock? will a 95-92 fit there?
    how about the sedan's manual pedals?
    sorry. thanks :)
    I can promise you all those questions have answers already posted ;) Especially the brake question
    Wagon looks good though, a bit of work ahead but good to see someone saving it
    hi guys,
    i really need rear brakes asap,
    i was looking at the EE/EF/DA Interchangable parts list and it says
    BRAKES: discs/drums - yes
    but nothing about the master cylinder and wheel cylinder. and booster, will they fit?
    also, can you guys tell me if a EF ignition switch (not tumbler) will fit?
    thanks
