new here RACEPAK'S B16 WAGON BUILD....
hey guys,
this is my first post here, i was redirected by rbwdriven from HT.
so i just got myself a 2x4 89' civic wagon its the only wagon in my contry
it dosnt have any major rust on it, except for some surface rust on the outer shell.
its original engine was a d15b2 and it was replaced to a jdm ZC
i also have a B16A engine with a S1 cable tranny from a SI-R that i had sitting for a long time that i want to swap into the wagon,
the engine is gonna be rebuilt with all new parts with slightly higher compression and new cams.
-the car needs some body work and paint and i need to order some parts from the us that i cant find here in my country.
hood WILL a 4dr ef hood or headlights fit to the wagon ? (sorry for the dumb q)
door and ignition switches (since the last owner lost the keys i had to break into the car to tow it)
again, are 4dr ef switches will work?
will 4dr ef brake lines fit the wagon?
axles? which axles do i need?
i will upload more pics of the engine later.
where can i get that plastic mold?
look, they made a pvc window :S
thanks
thanks
Plans sound good though, Bseries in a Wagon is fun. I have B18c with S1 gearbox in mine
iv been browsing the form and i think i found some of the answers i was looking for, but there are still some things that i'm not sure of,
are the rotots and pads + rear drums and shoes the same as a 91 sedan?
can i use door lock switches and ignition switch off a 91 sedan?
and the rear hatch lock? will a 95-92 fit there?
how about the sedan's manual pedals?
sorry. thanks
Wagon looks good though, a bit of work ahead but good to see someone saving it
i really need rear brakes asap,
i was looking at the EE/EF/DA Interchangable parts list and it says
BRAKES: discs/drums - yes
but nothing about the master cylinder and wheel cylinder. and booster, will they fit?
also, can you guys tell me if a EF ignition switch (not tumbler) will fit?
thanks
