Will these wheels fit?
I found some wheels on cl that I am thinking about getting but am having a hard time finding if they will fit. They are 16x9s with 225/40/16s. From what be researched on here some people said that try are running 205s with no issues. The only thing is I don't know the offset, but either way, would I have to modify anything to make them fit width wise?
Thanks guys
Thanks guys
Lowered or dumped? Not without some serious camber.
Here is what I did to help them fit
You can not run 225-50R16's on a lowered car because they are much bigger then stock, hence why I am running 225-40R16's. The only downfall to this tire size is the fact that only one company makes tires, Falken 512's.
Oh, and I have yet to have any rubbing issues.
Are you looking for a wide set of wheels and tires or were you just looking into them because they were cheap?
16x9 up front with 225
16x10 rear with 255
