2.5" drop springs... now no suspension travel
So I lowered my wagon with 2.5" drop springs and stock shocks/ stock everything else. Now there is zero suspension travel like you sit on the front of the car and it doesnt budge. I am thinking about buying some 1.5" springs b/c this is a every other day driver car for me and I want it to still be confortable to ride in. Anyone have any suggestions on why it is bottomed out? too much drop or what?
by the way I only did the front b/c when I set it off the jack I realized it was probably going to be too low for me. its hard to see in the pics but the front mudflaps are about 1 inch above the ground at the max.
heres a pic:
stock:
dumped:
heres a pic:
stock:
dumped:
cheap route = cheap results
Charb - thanks for your input but Im not going to put $500 worth of coilovers onto a $1500 car.
This is what I did, and it worked well.
1. Ebay adjustable coilovers. 50-100
2. Extended tophats. 75-100
3. Front /rear camber kit 100-200
4. Alignment 50-100
It will run you about 300-500
But no matter the worth of the car, if your driving it and want it to look and ride good, charb is right, its like a tattoo. A cheap tattoo isn't good and a good tattoo isnt cheap.
Hope that helps.
If you left all of the bumpstops in, thats probably your problem.
On other civics, I have been able to cut half of the bump stops off, making a shortened bump stop, and i also cut the lower rubber section of the dust cover off. However, when i tried this on my wagon, with EF struts and del sol lowering springs, the back bottomed out very easily (with me just leaning on the cargo area). Didn't even try the fronts.
I also recommend buying or making extended tophats... Home-made Top Hats
and /or
swapping to 86-89 accord front struts Shorter Struts
Are the rear springs installed in that photo?
Das a what i said!
And no, he said he only did the fronts, and realized it would prob be too low, so he didn't do the rears yet.
