The project begins
well its been talked about and i am going to do it.
K series awd wagon
the donor car is a 1991 civic wagon 2wd auto
only pic as of now.
the part list i have comeing .
K series AWD stick tranny from a 2003 honda element
transfer case from same car
shifter box and cables
rear awd trailing arms from a local yard.
k24 crv motor
any one that has parts i need plaz pm me with what you got
still need to look for
standard peddles for the wagon
used swap mounts i am workin on from a different site.
rear diff
rear sub frame the local yard has it just un sure if i want to try to use the 2wd one.???
jakers drive shaft ??? if it would work or i will have one made or if a member has a stock one i can buy.
i will try to keep you all updated with lots of info and pics. as i go threw this .
K series awd wagon
only pic as of now.
k24 crv motor
rear diff
x's 2
sooo back on the project wago awd K i got all the stuff to drop in the motor the mounts are here i just need a clutch so this week i am going to order one and get the mount welded in and the tranny straped to the motor and redy to go....
i will update again very soon with pic.... the project has no died guys it will live
i was going some talkin and the guys over at hasport are doing a similer built and i got a few pointers on what i have to trim and what not
the project.....
1990 honda civic WAGON
K24 awd
as far as i know there is only one other person over at hasport doing the same swap on his own time we have talked and swaped info and ideas and well be talkin more.
i will try to keep this as updated as i can but this is not a rush rush project it get done little at a time as i get free time at work and extra money to buy parts.
motor is a stock k24a
trans is a 2003 honda element.
transfer case is a honda element aslo
the front axles are stock base axles.
the rear drive shaft is a modded honda element.
the rear diff is a honda element.
the rear axles are yet to be made.
mounts are inovatave the rear mount had to be modded since the transfercase is in the way and i added a extra front mount like stock.
time for some pics.
trans fit ment
then swap in
hood issues
motor shimmed 1/4'' and trimmed very little
stock cross member trimmed and instlled.
rear mount bracket cut and bolted to one hole i have to weld on another tab and old it to another different hole. and i have a front mount added to the stock cross memeber also for more support.
shifter is on the plate now to get done
i then put the swap back in trimmed the stock cross member a little bit to clean the oil pan some more.
then i put in the drive side axle i had and the passanger side will be here tommrow with the half shaft.
then i decide to look at the header issue i will be faced with and well after some work with the chop saw and the welder i sectioned the stock header about 1/2 and pulled it closer to the block i now have it fit 99% i have to trim the cross member about 1/4 of inch and it will bolt on minty.
wile i was back there i cleaned off the fire wall of all the non needed parts..... stock mapp sensor fuel filter and brackets the evap cnaister and the head hoses.
drive axle in !
header fit mint befor cross member trim... i will trim it tommrow
fuel rail and pully kit is on its way250$
conversion harness is on it way motor harenss is on its way 400$
cable to hydro kit is on it way.200$
tommrow my pass side half shaft and axle will be deliverd 75$
and tommrow my element drive shaft and rear diff will show up300$
this weekend i will be taking a drive to see biohazard and get my rear trailing arms and my clutch peddle set up and then i can make my rear axles.
after then i need to just get the fuel set up done and get all the coolent done and then drop the big money on Kpro and try it all out.
Good luck on your build!
Looks like they were planning this 20 years ago
Also subscribed
but i did some more work today i notched the cross member for the header some what i have to do some more.
then i put in the half shaft and the pass axles so now i have all the axles in.
i started to fit the drive shaft and rear diff and well that fit suprer well also the leangth is right where it needs to be i need to make a mount for the center support and then make some more mounts point for the rear diff then that is done i will prolly tackale that this weekend
i really wish i could run a stock wagon diff but i am not sure if gear raito is the same as the elemnt tran i used so i bought a rear diff to match the trans... but if any one can help me out and tell me where to look for gear raitos for the the wagon and the element that would be grea if they are the same i can sell this one and just put a stock wagon one in...
Subscribed! Keep the updates coming.
People do orthia rear diff's though? Maybe investigate that a bit more perhaps
from doing alot of asking and talkin the stock wagon rear diff should hold up to my need i have a stock K24 and that is howi plan to keep it for now..
epic tuning civic hatch with the wagon drive train made 400HP and did not break the rear after 4wd burn out and track time then my daily driveing out of the 200 maybe K24 wont break it...
last night i ordere all the fuel fittins i needed and once they come in i will get the fuel done.
ordered my RYwire.com conversion harness and my charging harness they should be here this week some time..
after the fuel and drive train are done i need to make a exhaust and plumb the cooling system and then that should be it.... she should run and drive all that will be left is call my wiring guy and have him come do this Kpro stuff and see how it all works out
many more pics to come this week
