Suspension Upgrades
Original Thread: FF for $565 shipped or Ksport for $750? worth the $200 price tag difference? Purpose is for daily driving, but capable for some corners when needed.
Since no one replied, Im changing it to my suspension upgrades so far:
1. EG Function & Form Coilovers
2. Function7 LCA
TBI:
1. Energy Suspension Bushing + RTA
2. DA Rear Sway Bar
About to put them on right now so hopefully still as good. heres what they look like:
Cool, thanks for the adivce.
I forgot how much it sucks working on old cars. the lower control arm bolt just broke on me. Now need to find a way to drill it out.
I wish I could be giving feedback on coil overs, but still waiting on skunk2 lca. My stock lca, one side had to be cut due to broken bolt and one bushing came out while trying to take out struts.
I went to junkyard, found 4 door da and took out sway bar. My question is will this mount on? I didn't see any holes for the sway bar to mount to chasis?
Also would it matter which nut I use for the bolt that goes through strut and lca since aftermarket has no thing for just the bolt. I found that the nut for upper strut mount fits th bolt.
Value: can't get any better for $280.
Ride: a lil bumpy, but still pretty smooth. Havent scratched car yet even going through dips and such.
Recommend: yes
Maybe in the future, I will buy a set of ksport.
Where did you end up ordering your set from?
Yeah, just took it to shop to install everything. Got the kit from amazon: http://amzn.to/m89773
1. Tranny Shifter Stablizer
2. Shock & Strut Bushing (because I have aftermarket coilover)
Anything else you guys see?
I had the lca installed on the stock ones as well. Guess the mechanic said there's another lca set for just the 88 civics.
Haven't got it realigned yet. Probably do it this weekend. Car handles great now, turns without hesitation. Rear seems to be squeaky a bit and front seems to now make my car scrape the fenders (didn't do this before). Need to raise it up a lil or get smaller tires.
***Update: There was a lil slack in the spring, I should of have adjusted this before driving. Just adjusted this right now, the left front went up a lil bit and now the car is no longer as bouncy and doesn't scrape the fenders. Feels a lot more like a sports/luxury car now.
they are often overlooked. they are the ones on the rod that connect the front lower control arm to the sub-frame. they are hardly visible behind big washers.
Update: not sure, but it seems the car has more a bounce now when making hard turns at higher speeds?
