I need help from you suspension gurus.
I have a set of Tein SS with pillow mounts installed on my wagon, and have run out of travel on the greased collar.
For the car to ride were I want it to the coil has to be so preloaded that the ride suffers. I would also like to raise it a little bit more. The rear is fine.
So the question I have is,
Do I put stiffer coils in the front or
Do I put longer coils in the front or
Do I do both.
Do I do both.
The ride will suffer if it is too soft of a spring so that you either hitting the bump stops or coil binding the spring.
As you are raising the car I don't think would be an issue.
I would get a longer spring.. The stiffer spring will not help your ride.
Now another question should I add a hundred pounds of spring rate to the longer spring for a the extra weight of a b series swap.
