DA springs and struts on my wagon for this winter.
I know its far away but im already thinking of how to winterise the wagon i cant go throgh another winter with it lowerd. anywho i have a set of front springs and struts out of a DA and i know where to get a full set of rear DA springs and struts i know they will fit but does anyone have an idea on what kinda ride height i will get?
with the turbo, do you think you'll be pulling too hard for the height? just a thought. cuz if you punch it, the car will pitch back and the higher height might be a problem.....
this set up with turbo will be a new one. keep us updated
but yeah, the DA suspension should give you a slight lift. im guessing about an inch or so.
http://p196.ezboard.com/fhondacivicwagonfrm8.showMessageRange?topicID=6.topic&start=1&stop=20
it says that the DA suspension is a pretty much bolt-in affair. we already know this because a few people have done it. a lot of stuff was wiped out from that site, or is unrecoverable. any idea if you can find that article Si???
I really need to see pics of that setup!
I have been toying with the idea of lifting my wagon this way as well, but permanently.
Let us know what your handling is like as well.
Just to be sure, the old board has this to say about Integra suspensions:
Integra suspension of any '90+ Integra is an upgrade and is a bolt in replacement for what you have.
Is that accurate?
http://p196.ezboard.com/So-you-wanna-lo ... D=36.topic
It's only on the rear springs.
:idea:
You mean the adjustment part? I don't know if that would work due to the springs being different sizes. Let me go check I have both.
EDIT: The adjustable part on the ebay cheap coilovers will work on the front but not on the rear. The bottom coils are too far apart from each other. You would need to get some kind of a plate made or something and then i don't know if i would trust that.
IMHO its only an upgrade if you carry alot of weight in the wagon.
The info was added to curb a few misconceptions.
