87 rear wagon coil overs
Ok, so I've been doing a bit of research on trying to find a set of coil overs for the rear of my wagon and only company that I have found that makes something that would work as far as I know is ground control. Only problem with that is the price tag. So I went on ebay and found something a bit cheaper but I'm not 100% sure if they will fit. I messaged the seller and the measurements I got were 8.5inx3.75in for the spring and 6.5in x3.5in for the sleeve. So I went ahead and did a rough measure with the shock and everything on the car and came out with the bottom perch being 3in -3.5in and the top being 3.5in - 4in assuming this is the case these should fit?
Still waiting on my reply for RPR to get my membership there so figured I would see if anyone here has used these.
http://cgi.ebay.com/ebaymotors/ACURA-IN ... 588bf2efa7
According to the "what vehicles they will fit deal" 87 crx and 87 integra are both on the list so figured I would just see if I could get a second opinion.
-thanks
-thanks
Yes we do! What other suspension options do we have for lowering?
