Brakes are Finito!
My brakes have been acting up, and ever since I've owned the car there has been pedal travel. At a light it doesn't hold, pedal pressure reduces and then if I pump it, it will be ok. Today I took it in to have it checked out (since it was going for an alignment anyway) and they said the brakes are completely F*ed. They said that whoever did them before screwed them all up, and pretty much everything needs replaced. Here is the list:
Front Calipers
Front rotors
Front pads
Front and Rear wheel cylinders
Rear drum/shoes
Master cylinder
and if they do it instead of me...installed
*Basically everything is getting changes other than the brake lines*
Total ends up being like $1000
I could do it myself....but not sure how much I would save. Any idea what it should cost?
Front Calipers
Front rotors
Front pads
Rear drum/shoes
Master cylinder
DIY=The HCW Way
http://www.rockauto.com/ (thank me later)
Except my E brake. I got from Rock. It's good stuff for those extremely budget limited.
i didnt spend that much and i have a big brake upgrade on the front..
If you're going to replace the following:
1) rotor
2)caliper/Pads
3)MC
It's a good time to upgrade them to larger ones(larger 10.2"+ dia rotors;CRX Si(RTWgn.).Teg ,ITR,etc. caliper/Pads and Teg or Lude MC).Do a search on this site for upgrades.
Basically the RT has CRX Si front brakes.The wgn.rear are all the same.
x100
while you are at it, get a 1990-1991 Civic EX M/C. its bigger and has a firmer pedal feel.
