Bolt specs
Hey all, I have done some searching, even called the local honda dealer and I cannot get the specs of the torsion bar adjustment bolt for an '84-'87 wago. If anyone can find the specs that would be great! Thanks in advance!
90111-sb2-003 is the bolt part no.
Another way is to check on the web for a metric bolt torque table.
awsome! well i knew about the knotch but i guess i didnt think of grinding it. thanks. but a longer bolt could also do the trick and less work.
