Shx ???
I know there are many threads around about suspension, but I am going to ask anyway. I have a set of coilover adjustables and I need to find replacement shocks/struts for my 91 AWD wagon. I am running OEM 15 inch rims for the summer. I only plan on running it an inch or so below stock specs. Can anyone suggest decent replacements. That are not to cheap and not at the high end??
Thanks
Thanks
tociko blues cheap and not outragously priced my buddy has a set they are not overly stiff but definelty not stock. and if your wagon is an 88 u will need LCA's from 89-91 civic.
i always tell people...stay year specific!!!
People inclination to want to use later production years items stems from the fact that Honda is known for making improvements as the production cycle progressed. And since most people assume (not unreasonably) that the wagon was like the CRX, changes like 4 wheel disc brakes, more organic dash, "clear" bumper lights/corner lights with no exposed screws, more hp(89+) etc etc have lead people to believe that later is better.
You stooopid kid.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 8075447752
is this really true tho? i've always known that the ITR had the same rear suspention set up as the 88, meaning that Honda knew this was a stronger set up. you say i dont know anything, but thats why im asking. i may be a kid, but i can still learn.
Honda got rid of the 88 setup because the average CRX owner did not like the "twitchy" back end it caused. The larger ITR seems to work better with this setup.
yes those will work just fine on your wagon BUT u can not use your stock wagon springs because your ass end will be almost 2 inches lower in the back than the front. u need to get springs from a 88-91 hatch/CRX/4door or 90-93 integra springs or if u want to lift your wagon a lil u can use 99-00 civic Si springs.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... %26fvi%3D1
