Painting Wheels
i just bought some bmw bottle caps for my snow tires.
wanting them white, it cost $200.00 for powder coating.
im going to just paint them myself. i can't find white wheel/rim paint, only black and silver.
whats a good alternative brand/paint type?
krylon,duplo,vht.
ive seen post painting rim/wheel, but no brands.
thanks,
guys
krylon,duplo,vht.
thanks,
guys
Ive had a set of wheels painted before, colour matched to the car and it was just normal car paint.
Did 10,000ks on them and only had a few stone chips which is going to happen no matter what paint you use.
i guess its all in the prep work.
If the rims have never been painted before and are still on the original paint then just sand them down, making sure you get in all the corners and edges, and you should be fine.
Here's a cool method if you've never heard... playing cards. Two decks worth. I've painted a few sets of wheels, and this was by far the best method for me so far.
I'm pretty sure Billboard did a write up a long while ago with some good pics. Maybe in one of his threads.
Does this color the tires at all? Should this be done to take the finish off regardless? Mine is peeling...
I'm gonna paint my teg wheels once I get my winter tires put on.
Use your card method for the paint stripper as well, just don't get carried away with the stuff. Paint stripper will eat through some stuff but stuff like zip strip works pretty quick and you can just wash it off. It usually only takes a few minutes for it to eat through the paint. Get some soapy water and a brush and rinse it off. I have never had any problems with it doing anything to any of my tires. I am about to do my BMW rims because the clear coat is peeling and you can believe I am not about to pay some jack ass 100 euros to remove, reinstall, and balance some tires (yes it is that expensive here).
Not everyone has the means or the funds. :roll:
Plus if you have some beat up steelies that you just want to make decent why would you powdercoat and spend the money when spray paint is easy to get, and a hell of a lot easier to do (before you say it, I do have a powdercoating booth
otherwise just sand and clean
as far as paint goes
http://www.plastikote.com/products/Spec ... Paint.html
then heat them with a space heater and cardboard box
will most likely outlast the car
i've been reading the paint instruction and realized that its to cold to paint the wheels. my bad started to late.
couple of days ago a friend called me and said the powder coater has been trying to reach me, he said the coater is making a batch of white and wants extra pieces to coat.
blasted and powder coated for $100.00
i said done.
show pic. next week.
thanks for all the advice boys, it will come handy.
