Suspension Problem/Spring Recommendation Please Help!
Hello,
I just put on my H&R Sport springs and KYB GR-2 shocks and I'm really low in front. (Back end is fine, cut one dead coil off of rear to bring it down).
The problem is that I'm afraid the springs are too soft because I'm bottoming out on even smaller dips in the road. Keep in mind my front end is a little heavier than normal because I have a b18 swap.
What can I do, short of buying full coilovers? Should I get stiffer springs in front? Should I do the unthinkable and get some ebay coils for the front?
I got the H&R sports because I thought they wouldn't drop me down that low, and I'd be safe on bad roads... I was wrong! Help me stop bottoming out!
Try Eibach Pro-kit front springs.The spring rate is the same as your H&R's,but .7"(18mm) taller.
or
TANABE GF210 (orange) same drop as Pro-kit,but 20% stiffer.I know nothing of the Tanabe.
I'll try that after I give rubber coil spring spacers a whirl. They add 1" and claim to increase spring rates by 100lbs...
If you are just bottoming out the shock, you might try looking for a shorter shock.
What application was your KYB for?
The shocks and springs were all for an ef. I know the wagon weighs more (esp. with the b18), but I didn't think it'd be this low in front...
Spacers should be in tomorrow, gonna try them first, then switch to plan b if its still too bad.
me too! ...personally I think that you can never be "too low"
Simplyhonda,
We have the same setup, but mine never did look like yours...
Heres the stuff
The new powerplant
Crappy pic of the drop... there was less than half an inch from the mudflaps to the pavement.
I know its not super low compared to others, but the springs are sooo soft, and the front was significantly heavier, any dip in the road would mean *BANG*
Since the last pic, I got the 1" spacers installed in the front, and another coil cut off of the rears. Day and night difference! The car is much more level now and I'm not scraping on everything. Finally I can relax a bit more when I drive and not have to clench my ass cheeks for every little bump in the road.
I'll get some new pics up soon.
