Wagon suspension questions.?
Those of you guys that have dropped you rear with original wagon struts and EF springs...Would you recommend cutting the bump stops as well & why?
I know cutting the bump stops will help not bottoming out so easily.
Also on the front stock struts and cut EF springs. Do i need or should I cut the bump stops? I am for sure going to extend the tophats.
Yes your post did help.
