My WAGO project in east TN
ok, heres how i ended up wit her, i was building a boosted ef sedan and just so happened to see this wagon sittin in the weeds behind a car lot. It was previous sold after a water pump and timing belt job but the crank pulley bolt didnt get torque'd down so the bolt and key fell out, long story short no alternator no power so the car dies and the car lot refunded the money and then it just set there. I picked it up for 300 as is, has new water pump, timing belt, head gasket, intake mani gasket, axles, struts, etc. very minimal rust, just surface rust slight paint bubbling. everything works including ac. my plans is semi built sohc turbo or Hswap, already have the sohc turbo parts so thats my direction for now. Ive also picked up a set of recaros, some wheels and a rack.
when she came home
need a hood or bra(lmk if you have either)
only rust on entire car, the underside of the car is cleaner than the exterior, simply amazing
installed the rack
new wheels and stance
the recaros i picked up(need cleaned but hope to have them installed today)
The bumper is off cause im mockiing up the front mount and piping, also doing a diy home depot lip which in my opinion is turning out great, still need to add some support brackets but the basically just for shape. should have more updates today. Hope you guys like and input is greatly appreciated, thanks
when she came home
installed the rack
some turbo parts, t04b and t04e, a few different downpipe options
oil filter adapter, love this peice
hks bov
turbonetics couplers
Y8 intake mani and LS tb
updates to turbo install?
dont know what happened and why its blurry but its all i got at the moment
alittle plaid action
gonna get the recaros re upholstered along with rears before i install them
5 panel rear veiw
some random shots with the new wheels
-Full tuck and shaved bay
-traction bar
-ef half sized from ktuned
-custom rear wing
-ef mid wing
-Recaros re done and installed
-dye carpet red and some kinda door inserts,(wanna give it type r feel on the inside)
-Custom headliner
-Dual pop up moon roofs
-S2K gauge cluster
-5 lug(got a few ideas on how to this on the cheap, ill let you know if any of my ideas work)
-some sort of supermesh's or some re barrelled steelies
-chargespeed/J's knockoff front lip
-itr/keys/nardi wheel and knob
-Frost Mocha Metallic paint with custom mixed red bay(flannel bay???maybe)
-RHD conversion(LMK ASAP if you know where i can get the parts or clip to do this)
-Got some one off custom ideas but not sure if they will fit this project, ill keep ya posted if i decide to use any of those ideas)
-Some random JDMness, headlight squirters, lights, badging, etc. gotta be trendy
more to come
Let me know what your idea's are, and I can possibly point you in the right direction. I did a lot of trial and error when I built mine.
Here is a link to that thread. Read the entire thread, there is some really good info in there:
http://www.honda-tech.com/showthread.php?t=1978033
Thanks for the info, i wanna do alittle more research and trial and error before i put my ideas out there, just wanna save face if its not possible, haha but i will keep it updated if i try to go that route.
Oh yeah, redone alll the moldings, bumpers, window trim, liscense plate garnish, wiper cowl and wat not, looks a million times better now, cant wait to get the swap, tuck and shave done so i can get this thing to paint, hopefully be painted by 1st of the year, Frost Mosha Mettalic wit custom flannel painted bay
NEED A PASSENGER SIDE REAR MUDFLAP 2wd of will even take a pair of 4wd rear mudflaps.....PM if you have wat i need please
