Suspension, lowering the wagon.
yes yes yes.. i kno i kno. there is a perfect thread about this. im jus retarded and needa make sure im understand thing.
ok so use DA springs. and EF front shocks. now for the rear; you use EF OEM stock shocks? is that right?
i rather not use OEM shocks if im doing aftermarket suspension.
especially if i plan on dunkin it to the ground.
my perfect suspension would be koni yellows with skunk2. so do i have the rear oem shocks thing right?
use EF shocks. if you wanna raise the wagon, use DA springs. to have the DA springs lower the wagon, you'd have to cut off 2 dead coils, which isnt such a smart idea. even for the rear, use EF shocks. i've got skunk2 coilovers, so i guess EF springs would be just fine. the only reason why DA springs were brought up was because of the weight concern, since the wagon springs were meant for a heavier car, the EF springs wouldnt do, therefore DA, which was found out to be heavier than a wagon, springs were suggested to counteract this. cutting the dead springs would solve the 'ass-in-the-air' problem, since the DA springs are tall. but since you're lowering, EF springs will do.
check it out. can i jus do this.
buy these
http://cgi.ebay.com/ebaymotors/GROUND-C ... enameZWD1V
and these
http://cgi.ebay.com/ebaymotors/Koni-Yel ... enameZWDVW
and call it day, with a perfect, equal suspension height?
are you planning to autoX the wagon? im just curious because you're spending so much on GC coilovers.
that set up i showed you.. are those shocks and spring the ones i wouuld be able to get and would work?
i wouuld like to get skunk2 coilovers but what struts would i be able to use? what company
that set up will work, but in my opinion, save your money and buy something cheaper. those groundcontrol are GREAT for track use, but if you arent, then save the money. just my two cents.
whered you buy your set up?
and to get things right? i buy the skunk2 coilovers and tockio shocks for the EF application right?
yes, for the 88-91 civic/crx. if you have an 88, buy shocks for an 88. the coilovers are actually labeled on the box as '88-'00. so yeah....
since i got a 89, buy these:
http://cgi.ebay.com/ebaymotors/TOKICO-I ... 3246QQrdZ1
and these:
http://cgi.ebay.com/ebaymotors/SKUNK2-A ... 9194QQrdZ1
these are exactly what i can get right?
btw: i know someone busted their ass to write that suspension write up, but i still see people asking about suspension all the time. someone should rewrite it so retards like me can fully understand
we have a weener!
well if we re-wrote it so that everyone understood it, then why would you need us then? lol nah jk it's like a small familiy here, we're here to answer questions if you got em
USE EF SHOCKS AND SPRINGS. nuff said.
lol thats all it takes right?
im about the join the family. ill have a wagon by next week. and hells gona break loose! ill keep ya updated. thanks for the tips
I have ridden in many different cars with all types of setups and the function form didnt bounch all over and had more adjustability then any other setups.
http://www.hondacivicwagon.com/board/vi ... php?t=1585
what if i go this route?
http://cgi.ebay.com/ebaymotors/SKUNK2-S ... dZViewItem
its cheaper.
should i go this route? remember im gona be dunkin it!
i want my ride to not my bumpy.. bumpy as in cut springs/ebay coilovers type of bumpy.
and i wana slam it. what suspension set up should i go with?
earlier we said skunk2/tockio would be good. but the skunk2 coilovers full kit is cheaper. again.. i want to slam but not be bumpy.
KYB AGX are $275 or so....compared to Illuminas for $370. you get the fully adjustables for rebound and compression damping.
or go with non-adjustables. KYB GR-2 or Tokico HP. wayyy cheaper but you dont get any adjustments.
it really comes down to what you want on the wagon. if you think the full skunk2 set up with suit you, then by all means go for it. but if the wagon isnt going to see any track time, and youre gonna slam it anyway, its not really worth it IMO. what you want on your wagon, you put on your wagon.
Alan
what suspension set up is the best bang for the buck for me.
i think im going with agx right now what coilovers.
btw i was coilovers not springs
because with a coil-over sleeve and even lowering springs, it makes the strut use only a fracton of its travel. so if you modify the strut mount, making the strut be able to go through its full movement you will gain some ride quality back.
also a taller sidewall (tire) will make the car less bumpy.
