Bit of a problem?
soooo i ordered skunk2 coilover sleeves for 88-00 civic's. and i've got kyb gr-2's for a 91 civic hatch. but when i went to install the rear coils on the rear strut, the mount/top hat is NOWHERE near the spring! even with the coilover sleeve adjusted all the way to the top, there's a good 2 inches of space between the strut mount and spring.
what exactly did i do wrong here?
i'll double check the spring part #'s again tomorrow. seems to be the only reason they wouldn't work right? unless i was sold the wrong rear struts.
The smaller springs at the top, they keep the main spring captive and instantly compress once the weight is on them, you will probably want extended tophats too so that the shock still retains decent travel
