rear 2wd crossmember on 4wd wagon?
Is it possible to install a 2wd rear crossmember on a 4wd wagon. I am not using the 4wd anymore because the driveshaft was not there when I bought the car. So the problem is that the rear rossmember on my 4wd wagon is rotten and the lower arm detached from the crossmember. And the only crossmember I can find in Quebec is from a 2wd wagon. Since I am not using the diff in the back, I would remove it and install the 2wd crossmember. What do you guys think?
Thanks guys!
