Cheap ebay camber kits
i got some of those cheap noname upper control arm camber kits on ebay. well... the name on the arm says BBP.
put them on today. the shits stick out too far and hit the edge of the frame on every bump at STOCK HEIGHT!
i wonder if i got the wrong part or if this brand just sucks that bad.
anyone have experience with these? ive seen some people with some that look like mine.
http://cgi.ebay.com/ebaymotors/1988-1991-HONDA-CIVIC-CRX-FRONT-UPPER-CAMBER-KIT-ARM-90-/160448873554?cmd=ViewItem&pt=Motors_Car_Truck_Parts_Accessories&hash=item255b7f8452#ht_3530wt_1165
on another note... i had to redo my power steering upgrade...
while turning the steering wheel with the car running to run the fluid through the system i noticed the wheels were spinning even without the car being in gear.
they would only stop when i pushed in the clutch.
Is this normal??
OH and one more thing... if you accidentally pull the cv joint out of socket is it fucked? lol
because i did this...
Is this normal??
you have camber on stock height? or why did you do this?
if you look at the link, you can see in the picture that the metal sticks out the same no matter where the ball joint is.
i emailed the company about it but its past their return period...
The fricion of the oil between the gears will cause the wheels to move with no load. It's normal.
I suppose you have them fitted to the car now, but it would be extremely useful to see a stock one fliped upside down, on top of it and lots of pictures and measurements taken.
If it's hitting then it's too long and that's weird becasue it would have come out at the design stage (least you'd think so) unless the inside of a shuttle wing is much closer to the arm than a sedan, hatch or crx ??
good to know about the wheels moving with it out of gear. it didnt seem normal to me
i can get pictures of how the control arms sit now. and the scratches and dents in them already from driving once to work.
today on my way home from work one of the bolts came out from the sway bar mount... haha and it fell off.
i swear i tightened that thing down... o well
maybe i can take better pics when i fix that
left
right
you can see where its hitting the top with the damaged fender lining
i just hit it with a hammer you cant tell. idk why those dam things are so long. >:(
The sliding plate ball joint must just come out quite far so they've had to extend it.
Makes you wonder WTF they tested these (assuming they did) on as a lad here is saying the same thing for a CRX fitment.
Skunk2 ones which are a very similar design do not have the problem.
There were some custom ones made here for a few sets which used a TRE style link you had to screw in and out to adjust, so no chance of it coming loose like these ones or skunk2's.
<-n00b sry
i saw someone on here selling some rear lcas that were threaded for camber adjustment. seems to me thats the way to go. with the wheels im planning i dont want them sticking out more. id rather set the lcas in a little bit to correct it.
You probably call them something different over there no doubt.
The end of teh steering rack with the ball joint on it.
Please enlighten me. Another one to add to my US car vocabulary
hood = bonnet
truck = boot
rocker panels = sills
fender = wing
and so on!!
i was thrown off. wasnt thinking in that area because it doesnt have to do with camber. but yea that style.
i need some help ....
Scrappy is down ... i was searching ebay for parts and came back here to read up on different lower costing stuff ...
i sit higher not lower .....
this is a pick of my fenderwell
whats the chance it can hit the same spot on Scrappy as it did for OXBEARD..????
upper ball joint fell apart as it was removed i was told and the bushings r shot ... so buying an upper control arm with all is my best bet and probably cheaper
I think.....
but now its time for POSITIVE help....
No B.S. is wanted so keep all stupid comments to urselves
THIS!!!!! where can i find a set of these?!?!?!?
as per chip's post....what are your cost differences between a set of skunk2 adjustable upper control arms and a blah set of non adjustable upper control arms? I'd say yours are just worn out due to the amount of miles on the chassis its self, not so much due to the lifting of the wagon. I have had my lift for like 5k in miles and i have not had an issue with my uppers yet, i've even had them apart numerous times doing several installs of other stuff.
Now my outer tierod ends are fucking hammered. both sides infact. I'm not sure if its due to the lift or due to the age of them....i plan on getting vatozone replacements and seeing how long they last...if they die again soon i'll look into something upgraded and or just make my own....
With your lifted stance I don't see you hitting the inner fender, but if you put bigger tires on you may hit the inner sidewall. That's one of the factors I looked at when ordering my wheels and tires.
lower inner bushing #8
lower outer bushing #11
stabilizer bushing #9
sway bar bushing #4
end link #14/15
upper ball joint
upper bushings #12
lower ball joint #9
outer tie rod end #19 &17
inner tie rod end #13
Look at rockauto.
You might save some money.
u guys might not b all older than me but U all have much more knowledge ...
so im listening and learning ....
comparing prices so i can order this stuff and get Scrappy back on the road...
