Header for RT4WD?
Did a little searching, didn’t find what I wanted.
I am looking around for little things to do to the wagon while I wait to get the body work done. It’s the RT4WD version, so there is the D16 in the bay.
I just finished the JRSC on my hatchback, so I cant use the AEM intake on it. So I will be putting that into my wagon. I figured what the heck, may as well do a header too then.
I remember reading somewhere that because of the setup with the 4WD, a regular header wont fit. Can someone verify this? Is there any modification that can be done to allow this to fit and work properly?
Thanks guys. In case it matters, I was only looking into a cheap chikira header I found on the local boards. Any help is good!
PS
I read the sticky on this, just wanted to know if anyone has actual experience trying to make this work?
PS
Thanks!
