B swap linkage problem
                    im using aftermarket linkage for a b swap into an ef. i know the linkage works because it was in my crx then in my old sedan now going into the wagon. the problem is it about an inch too short. i looked over the motor and it in there right all mounts lined up. so is wagon linkage different from civic?
they should be the same i know my friend used a jdm b16a linkage in his worked fine
does anyone have a regular civic stock linkage laying around? i can compare measurements to my stock wagon linkage.
I'm going to stick by my original assertion: It will fit the same as other Civics.
I used an angle grinder with cutoff wheel to cut the original welds like this:
Then sat it on the car and rewelded, I didnt change the length of the other rod so it leave the shifter sitting forwards slightly, to get around this I heated the shifter and bent it a bit more, my shift bushes are shot currently so its a bit sloppy, but once I get some new bushes it should be much better
