Leather seat install(Different Wgn Seats)
So a few years ago i pick up some TL seats on ebay. Sold to me as integra seats and i never used them. Yesturday i installed them into my 91 rt wagon during the next couple of days i plan on putting a nice set of s2000 seats into my wagon
Do EF seats hatch, sedan, CRX seats fit perfectly in the wagon. I have read a lot about cutomizing seats like DC2 and TL seats and Del sol seats.
im looking for a simple bolt in and out swap. maybe some seat pan swapping but nothing that needs serious cutting and welding
First, what year and model wagon? The 2wd wagons have more options. From what I've read, you can bolt in SI seats(ef, both honda-tech and the old wagon board have info) which fit in after a fourth hole is drilled into the seat. You must use the same year seats(those damm seatbelts!) as your car. If you have a RT like myself it becomes an instant mod job. RT's have a wider hump between the seats which leaves you less room to work with. So w/o taking the seats apart, you're best bet are custom brackets( which is covered on the old board).
http://p196.ezboard.com/fhondacivicwagonfrm10.showMessage?topicID=178.topic
Brackets:
http://p196.ezboard.com/fhondacivicwagonfrm15.showMessage?topicID=41.topic
I'm in the process of installing prelude SI seats and I'm using the pan swap technic(you can find info on honda-tech).
yes thank you I have seen all of that. the problem is that all those threads mention a seat pan swap but many people just stop there. they say the seat backs dont bolt up or custom brackets are needed.
I do not want to drill anything. I think many people stop at just the seat pan and do not swap reclining mechanisms as well. the entire piece is mouted high up into the seat back frame. you need to take that out. hence my JDM s2K seat in my DC2 required this for full recline.
