b18a1
                    im putting a b18a1 outa a 91 ls integ in my 91 wagon, i was wondering if i could use my stock wiring harness or if i should purchase one from a speed shop?
their both obd0 motors
stock one or the one out of my ls?
and also i was reading something about dual point to multi point
do i have to do that conversion also?
You'll use the PR4 ecu from the Integra.
viewtopic.php?f=7&t=4941&hilit=mpfi
viewtopic.php?f=7&t=3989&hilit=mpfi
viewtopic.php?f=7&t=2775&hilit=mpfi
viewtopic.php?f=7&t=2209&hilit=mpfi
viewtopic.php?f=7&t=1107&hilit=mpfi
viewtopic.php?f=7&t=74&hilit=mpfi
I would suggest researching terminology and familiarising yourself with Hondas in general. This will make your search far more fruitful.
MPFI = Multi Point Fuel Injection
DPFI = Dual Point Fuel Injection
MPFI has an injector per cyl whereas DPFI has one injector per two cyl.
