unexpected changes to the ol' engine
                    Head gasket went out on my wagon about a week ago. While taking the exhaust off one of the exhaust studs broke off.
Turns out a friend had a z6 head that he gave me a sweet deal on.
So it's mini-me time for my 89'.
I'll post up some build pics here in the next few days.
w'll be waiting ...
Realized that the drivers side motor mount is shot this afternoon. Not in my budget. Gonna weld a solid mount to use temporarily.
thanks
wagon.................4ever.......................
Fill it up with Window Silicone from Home Depot or something. Thats what I did to my mounts, helped but I can definitely tell they are solid.
bust out the old manual (or download it
Getting the oem gasket material is great fun! You can find several threads/ compliants about it on hondatech etc. It looks like I sanded the sealing surface in the picture... I didn't, it just looks all blinged out because of the flash.
Pull the oil jet in the middle of the rear of the block!
Did a lot of searching and got great feedback on this top end gasket set, from this seller. http://cgi.ebay.com/ebaymotors/ws/eBayI ... &viewitem=
I'm using the Z6 head. if your using the y8 head used the gasket kit for it.
At this point I've just got the head back on. Havent started torqing down anything. Dropped my cleaned up valve cover for inspriation.
There's quite writeups on mini me on the web. I'm just gonna give a quick overview of how mines going.
I'm gonna run it without the vtec working for a few weeks untill I can save up the cash for a obd0 to obd1 conversion harness and a non modified p28 ecu. rpm switches, piggybacks, and all that crap just doesn't seem like the way to go for several reasons if you ask me.
Here's a few pics.... will ad info as I make progress
Spent some time cleaning off the PS bracket, it was caked full of old oil and crud. Looking for a little better info right now on the best way to ghetto mount the a6 distributor on the z6 head. will post more pics when it looks different
i did that with mine he front and rear were shot..when i did my swap probably shoudlnt have done all of them but i thought what the heck......engine barely moves but car vibrates like hell at stop lights ...lol
The a6 spark plug wires don't work with the z6 head. Since I'm doing this swap on a tight budget I'm gonna make them work.
They don't reach because the rubber "lip" on the plug is to big and keeps the plug wire from going down into the head enough to grab the spark plug.
So I cut the lip off with a razor blade. Don't see why it won't work. Of course i'd love to have the extra cash to just go buy new plug wires but...
Tell you the truth... if they work well, I'll prob drive around with them until the plug wires get old and crunchy and need to be replaced.
here's two pics of my ghetto mod...
now they reach in just fine, and connect on to the plugs with a nice solid pop.
cutting yourself
while at it
thats ghetto
so ...
great mod, good to know
Need to adjust valves, do electrical connections, rig up the a6 distributor to work temporarily (till I get a the z6 dist, p28, etc.)
Be trying to clean up the bay a little while I'm working on it.
here's some pics with better light.
Kinda lucked out. A good friend of mine just shipped out to Afghanistan yesterday. Asked me to do him a favor and hold on to his GTI for him. "can you please drive it at least 4 or 5 times a week".... Yeah, think I can manage that
Now I don't have to fit any work in between the car being my daily driver. Don't get me wrong. It's what I want to drive everyday. It's just really nice to be able to take the time to fix up my wagon proper.
Pulled the head and off to the machine shop with it. The machinist told me that d-series heads are really bad with exhaust valve guides.
So I've made up my mind to rework the head. It'll get a flycut, 3 angle valve job, and new valve stems in the exhaust side.
Considering having a stage 2 port and polish done on the head. It's pretty pricey, but then again the car is paid for.
I may have decided against the swap if I would have known how far this could go, but i've already got the p28, conversion harness, head, and dist. bought so I'm going for it.
I'll end up putting more into this motor than I could pick up a jdm swap, but I've stated what I feel about jdm motors on here before.
Could be the deck of the block, or even rings going bad.
Did you do a compression test?
The exhaust valve guides were pretty loose. The machinist pointed out that to really get a feel for the fit you have to pull the valve, clean off any oil, and place the valve back in the guide. It's amazing how much slop a little oil/ residue takes up. they were noticably loose after cleaning them off.
