CV axels Replacement: what works for you?
                    Well i was curious what’s your technique to replacing your cv axel with the lest amount of effort and time?
Also when replacing them could you mess up your alignment?
You take the axle out of the hub like normal then use the vagina expander thing to expand the CV boot and slide it on over. Kindof like a mechanical condom.
No i'll let someone who knows what they are talking about explain it.
I'll have to respectfully disagree, sir. Alignment won't be affected.
loosen the axle nut/remove it
raise and support the car
remove wheel
remove cotter pin and nut from ball joint, then separate joint
remove bolt/nut from strut fork
swing knuckle out of the way while pulling axle thru
use a large screwdriver to pop the axle from the trans, pull it out.
then put it all back together! I always change the output shaft seals, too, and it's a good time to change the oil.
EDIT:
This forum won't allow me to post my actual write up due to images/size/number I guess, so follow this link - it's step by step, picture intensive and has helped literally hundreds of do it yourselfers do an axle swap in no time:
CLICK ME NOW
I've replaced literally hundreds of axles, and have done it with no air tools, on the side of the road, or at the dragstrip, etc.
Have fun!
Try as I might I was unable to bust my lower ball joints loose. (Yeah yeah, make your rude comments now and then STFU.
disconnect the swaybar link, then remove the bolt from the lower control arm on the engine (inboard) side.
turn the steering wheel to the opposite side joint you're working on so the tie-rod is pushed out then you can swing the entire suspension out far enough to remove the stub from your hub.
If you're counting that's two bolts and and the giant nut on the stub to remove... Then of course if you're working on a manual you'll have the filler bolt to remove and add some oil.
Four all together if you're ready to catch the tranny oil when you pull the axel out, five if you drain the oil first. And on top of all that, you don't have to mess with your balljoints.
You make it sound like you own a alignment rack
Yeah going to get sim cv's n fix my ride, after i get my tax retures though.
this goes for lowering as well. if you drop your ride the wheels toe out, if you raise they toe in.
wishbone style hondas are superior autos and a civic was blessed to have such a treat. dialed in the right way you will smile when you drive. out of wack they can be a little scary.
I aligned my 1992 Civic after mounting some new tires. TWO days later my right axle snapped in half, so I replaced it. A porter at the shop at that time was giving me shit about "haha you just did an alignment and now you'll have to realign it because of the axle" and just to prove him wrong I put the car back on the rack post-axle and the specs were eactly as they were (give or take .01-.02 since the laser heads never read the same twice) the few days prior when I did the alignment the first time. He also had to buy me lunch for wasting my time for reracking my car.
I agree that for suspension work you want to realign the car, but axles are drivetrain, not suspension. The only thing even remotely suspension related is the fact that you remove the through bolt that holds the lower shock fork to the LCA, and contrary to some people's methods you do NOT have to remove the lower fork from the strut, so there is no potential change in ride height, etc.
I've worked at this shop for 9 years now, and for 8 of those we've had this alignment rack, and I've done literally hundreds of alignments on just Hondas and Acuras. In the 8 years+ I have never, literally ZERO times, had an axle install cause any adverse affects on the alignment on a vehicle.
BTW:
Ask Revmaynard how quickly I can swap a CV axle out, on my back/side in a driveway. I'd say literally 5-7 minutes tops.
Well I set it up on the alignment rack and adjusted the toe as best I could. Its better but sooner or latter ill will have to get a new lower arm and realign it.
Also i notice that the caster and camber is not adjustable? So How does one go about fixing that?
