D16a6 Cam/ head questions
                    I've been reading up about this, am going to put the Si cam in the pebbleswagon along with the rest of the mpfi swap. I read somewhere that the a6 head casting is identical to the d15b2, true? Are the valves the same as well?
I ask because her engine has a newly done head, if I can just use the cam and followers from the d16 head, groovy. But... if there are advantages, I can use the whole Si head (after re-work)
Clear as mud, right?
if you have redone the head already just throw the cam in there, you dont need to change the followers just a valve adjust.
but then again, the follower has 3 contact surfaces, and only 1 is the cam lobe, duh. You're right! I want to get this done before the big SE caravan to Savannah in FIVE WEEKS!
