Seafoam
                    OK so iwas having some problems with my lil wagon like sputtering and sluggish take off. I had changed the spark plugs rotor and fuel filter on it and that didnt help at all.So i was pretty much stuck on what next to do(so desperate was even thinking about getting another car)So anyways i went down to autozone to see if they had a clue on what to do and the guy suggested i use seafoam so i figured ok another fuel cleaner that wont work like the rest of them.But to my surprise this stuff is a miracle in a can.You would swear that my engine is new (till you looked at the mileage 180,000 +)For only 6 bucks it is amazing what it does.But heres the warning 1st follow directions step by step and second close all doors windows and everything else because it is going to pur out the smoke bad.So anyways i didnt know where to stick this so i put it here.If a mod has a better place go ahead and move it there.
I'm even thinking of getting a can or two when I'm in the States later this summer 'cause I can't find it here in Canada.
Cheers !!
Its called something different in canada. I don't remember what tho. :roll:
An alternative may be the GMC "Kleens" product, or the "Mopar Combustion Chamber Cleaner".
But considering that I have 300k on the original factory d15, it might cause me more harm then anything. I should probably invest in newer seals before attempting anything like this.
Thx, I'll check out the local NAPA.
http://www.youtube.com/watch?v=k2IKrHOVgU8
-Syd
I've heard you can use that stuff all kinds of ways. I used it as a fuel additive. I think you can use it in oil, too - just want to change it pretty soon afterward. It's one of those things that sounds like snake oil, it's too good to be true, yet I haven't seen evidence that it isn't as good as claimed, or harmful if used as directed (obviously putting it in your oil and driving 50k miles without changing it isn't a good idea
Seriously, if you're not sure about it, DON"T DO IT! You can do more harm than good.
My first reccomendation to my friends who want to use seafoam is always to first check your air filter, clean your throttle plates with throttle safe carb spray(dont screw up the teflon coating with non approved cleaners).
on the last 3 cars i bought the throttle plate was so dirty it was night and day after i cleaned it.
we also took emission tests before and after to see if it was effective.
ill post a pic of the results on my next comment :P
I noticed immediate changes in idle and throttle response. I also noticed a change in my fuel mileage in a + way. I was getting about 20.5-21.3 mpg city/highway combined. Just filled up tonight and the mpg's jumped to 22.7 with the same amount of driving and a bit of harder driving as well.
I'm very impressed!!
When I tried to restart, it was obvious what had happened. I pulled the plugs and turned 'er over to let it out, no harm done, but it could have been ugly!
i have the before and after pics of my emissions tests
Haha that is awesome!
Not my car, but same engine:
http://www.clubcivic.com/board/showthread.php?t=98264
Just in case you would like to know how to in the future.
Pour it in your gas tank
or
Buy a can of their "deep creep" spray and run it through a vacuum line
or
Pour about an ounce in your oil before an oil change, drive for 10 min, and immediately change the oil. My oil has never come out blacker!
If doing seafoam i would recommend changing your PCV valve too helps tons!
I use two bottles for this process though. 1/2 in oil (right before an oil change)
Other half in gas tank and let her idle for about 5 mins and drive hard for 10 mins.
When i got back I did the vacuum trick 1/2 a cup.
Plug the line back in and let her sit turned off for about 15 mins. Turn her on and watch the fog machine go...lol
I used the other half for cleaning i mixed it with Simple Green
Drive around if you think your neighbors don't care or do this in a safe area. But i recommend doing it at night :twisted:
Oh and for those of you that are a little slow...don't do it in a closed garage lol.
you're supposed to change the plugs after anyways. NGK coppersss:)
