B16 question
                    i went through 17 pages and didnt see a direct answer, so i figured id just ask real quick.
I currently have a 90 crx si, with a b16. Im tired of the crx, and am looking for a wagon.
Will my current b16a, hasport mounts, shift linkage, header (4-1 had to notch crossmember in crx) all swap right into the wagon?
And how about rear disc brakes, are the trailing arm/brake setups from the crx a direct swap?
Thanks!
When i get one (waiting for a clean one in a 500 mile radius from oklahoma city) i will post up some pics.
Thanks!
I remember when I did the LS swap i had to do a bit of notching on the crossmember as well.
As for the brakes IDK, I know you can do it but IT THINK the trailing arms are longer on the wagon.
thanks.
As long as its a fwd wagon. AWD is a whole different story.
And i am looking for a FWD wagon, not really wanting an awd.
thanks!
thanks!
what wire/plug are you talking about? when i did my MPFI swap i used all the DPFI plugs with the exception of the Dizzy wiring.
to add VTEC dont you just have to run 4 extra wires for VTEC, oil pressure and o2?
