????-- (boosted 4WD)technical questions---????
                    I am thinking of building a turbo d16a6 and my goals are 300(ish)whp.
so my questions are:
-Will the transfer case and rear diff hold up to the hp?
-Is there any way to "BEEF UP" our AWD rear diff, and tranies?
TWO other things I was thinking about (left field)
What IF you remove the front CV shafts on the AWD? what will it do?
AND
Is there any way to LOCK the transfer case to make our wagons FULL TIME AWD?
AND
What if you weld a solid piece in place of the the viscous coupler?
Uhh :oops: You already psoted this in the stickied thread!
The CRV transfer ratio (transfer gears reduction) is .434:1 (this is straight from the Helms), and the rear diff ratio is 2.533:1, so that translates to .91 revolutions of the rear diff (wheels) for every revolution of the front diff (wheels).
You do understand that the rear diff ratio in this (Wagovan RT4WD) doesn't mean the same as it would for a normal RWD rear diff ratio. If this was set up as a RWD, with the gearing for the transfer case this would effectively make the FD more like 4.87:1.
Theres also no lock on the coupler to make it solid. But the setup practically makes it fulltime awd anyway.
People seem to just assume that the AWD system on the wagon is lame and similar to the CRV which it isn't.
I don't think i've seen any video's where a 4wd wagon's front wheels have spun freely without the rears. (Again, unlike the CRV's which allow 1-2 revolutions before sufficient torque is transferred through the clutch style transfer)
Just interested.
I'm pretty sure he ran the half shaft into the tranny on the driver's side, and used just the inner joint off the passenger side axle to plug the holes in the transmission.
He did some custom work with the driveshaft. Have a look for all his posts. I'm pretty sure there's a picture of his driveshaft here somewhere.
I think I will end up going the turbo Z6 route and what would I need the motor mount inserts for other than stiffer mounts?
