clutch problems
                    Hi all. Long time no see. I've been too involved with fixed gear and bmx bikes so I haven'} been here in a while. Anyhoo...
Seems like I have a clutch issue. Yesterday, driving to work I smelled burning fluid coming from my engine. Kinda sweet smelling but not like coolant. Then after that I felt like I lost my clutch pedal. The free play is now bigger than clutch pedal resistance.
When the clutch pedal is engaged, the travel is very short and I have a hard time getting into first and sometimes 2nd. I'm going to try to adjust the clutch later at lunch. Anything else I should check? Thanks guys!
Might want to check the fluid level in the trans too.
Once I got home, I filled up the tranny and readjusted the cable. When pressing the clutch pedal, we could hear a squeeling sound like metal on metal. That's not good right? It sounds like I'll be needing a new clutch... and soon!
Anyone else have any suggestions?
And dealing with it for a couple weeks, I discovered that turning the car off and putting it into first then starting it again worked out pretty well.
Most of the time when the clutch goes bad, it's slips when you stomp on the gas. I know I took a photo of my old bracket with my phone, I'll try and post it. I know I looked at it for a good minute or two before I figured out what the deal was.
I don't think it's the actual clutch since once in gear, it doesn't pop or slip out. Also since I'm getting a "whining" sound (kinda like a loose belt or something) the throw out bearing or something along those lines sounds more like the correct problem.
Now if only I had a lift in my garage. Anyone do tranny work using ramps and jacks? This sounds like a problem I may have to have done at a shop. Plus they have the experience as well since they do a lot of Honda work, from race cars to regular commuters.
With a partner turning the steering wheel it will give you enough room to push out the whole strut/spindle and get the axles out. The parter is there to turn the wheel moving the tierods out to give you enough room.
The rest is all just turning wrenches and keeping track of your stuff.
The neat thing is you can wiggle the spindle with you feet when you're putting the shafts back into the tranny, just seems to make life easier.
