My SOHC V-TEC Build
                    Sooooooo.....  This is what I've decided to do:
Once I have all my parts amassed, I'm going to try to do this all in one weekend (Everthing should go as planned as long as I keep beer out of the equation).
Parts List:
A6 Block
Z6 Head (valve job, mild port/polish, stock vlave train)
Y8 manifold with A6 obd0 sensors
OEM: Water Pump, Oil Pan Gasket, Z6 Timing Belt, Tensioner, Front Oil Seal, Piston Rings, Valve Cover Gasket Set, Valve Cover Bolts
Aftermarket: ARP Head Studs, Rod Bearings, Head Gasket(1.5mm)
Xenocron chipped PS9 One-Wire Vtec Ecu with obd0 B16 program and base D16Z6 program.
Sidenotes: With this set-up, I've calculated compresion around 11.3:1. Should be streetable?!?! The reason I am using aftermarket rod bearings sucks :oops: but if I'm going to do this in a weekend, I'm not going to be able to read codes then go to the Honda Dealership and order the bearings I need. I figure if I pull the engine, drop out the old slugs/rods, insert ZC slugs/rods then reassemble the engine I should be fine. :shock: Does any one know where I can find a 1.5mm head gasket??? :shock: I've been looking but can't come up with one reasonably priced.
If anyone has anyother info or parts that should be replaced, I want/need to know. Everyone's opinion counts with me
Just don't turn this thread into a peter pulling contest :evil:
Parts List:
A6 Block
Question, and I'm asking honestly because I'm not sure:
Have you checked into the compatability of the A6 IACV and the Y8 manifold?
Also be careful when you buy your Y8 manifold - make sure it's not one of the ones with air injection or it makes it more of a PITA because you have to block the extra ports off or else you'd have a major vacuum leak.
YO B18C5 check out this PDF file and let me know what you think. It's a A6 ---> Y8 IM conversion. I read through it but since I don't have the Y8 manifold sitting in front its hard to visualize what plugs and sensors need to be switched and such.
http://www.geocities.com/joeyp_19/articleviewer.html?view=d16y8manifoldswap&file=.pdf
Just my opinion but if the motor needs should get new bearings then it might be best to bore it out to the first oversize.
I was told from a reputable guy who races that I should just replace the upper half of the rod bearings and the bottom half of the main bearings even in the 190k mile motor I will be rebuilding. Hes been racing like this for 10+ years and never really had a problem. I think I'll replace them all being its a daily driver but if I ever feel like doing a motor cheap that will be one place to cut a corner.
Honda says to leave the cylinders alone unless there is pronounced score marks, no honing at all. Now if its needed then I will and I will definetly be checking the bores so I know they are not the shape of an egg. I've heard of stories of crosshatch still being present on motors over 200k miles, maybe its just BS. I'm not pulling the crank just going to drop the rods and pistons in and like I was saying before, I won't have time to get the proper color-coded/diameter bearings from Honda. And I sort of see where your racing buddy is coming from seeing how it would seem that most of the pressure is on the top rod bearing and bottom crank bearing but I'm gonna say that the top and bottoms of both get equal amonts of force. But yeah, if I had more time and a little more cash and I wasn't impatient the block would have nice, new OEM bearings.
I didn't know honda said that.....interesting. The original d16a6 that was in my car became hydrolocked at 197k and it still had good crosshatch. Another one I looked at with about 190k on had very little visible but you could see the crosshatch if you looked closely.
Good luck on your build. I will be "building" one shortly as well.
All four pistons are f*cked!! Well shit, anybody have any other good piston/rod combos. I could just stick with my A6 pistons/rods. LMK what you guys think
Yeah I think so, after I vacuumed and installed the fog and I'm sure after I wash all the road grime I'll fall in love again. Now that things have settled down and I ahve some time to work on the wackovan, I'm hooked again!!!!
Atleast wait til I have money and can pick it up lol
thermostat, wire tuck while everything is off, paint valve cover while its off and paint heatshield for stock manifold if you are to retain it, prepare for new vacuum line/hose replacement just in case.
As for your rods/pistons I would consider this http://www.knology.net/~jediklc/pistonnotes.htm
I've always wanted to try that with a proper cam (272 maybe) and see what the D16 can do at 7k +.
Though thats starting to get a little pricey for all of that.
