B16 into a third gen wagon
                    im gonna throw a B16 on my 85 wagon :twisted:
im new to the wagovan scene and any tips on installing and can i use other parts from another civic or crx for suspension & brakes etc.
Fuel injected models have an entirely different fuel tank, lines, pump, engine harness, body harness, etc. etc.
The only way I can think that this could even work is if you find a PGMFI 86/87 Civic Si HB complete car and try to retrofit it's fuel tank (if it will even bolt in), lengthen it's body/chassis harness, etc. etc.
This swap will end up soting you 5 times what you paid for the car, easily. My shop has done a B16A swap into a 1987 CR-X Si and the mounts, one-wire ZDYNE VTEC ECU, custom axles, etc. all added up to more than the B16A itself costs.
How much money do you have to try this swap?
We used suspension crap from a 86 Integra for the front and just regular coilovers in back.
hasport has quoted for 3rd gens do a ls is fun, scare yourself try b18c. went somthing like that, ha ha
Click Here For HASport 84-87 Civic/CR-X B swap products
Hey Lucskywalker when you did this swap what mount kit did you use? I think the mounts determine the axles.
you might be right my friend, i didnt use a kit i made my own because of the simplicity of how 3rd gens mount it was kinda easy.
i just said hasport cause i liked that motto 8)
