car don't want to start sometime.
                    I use wagon mainly on weekend.
car will start right up with no problem at first. The problem is that when i try to start it again after I turn the car off. not thing happen( not turn,crank whatever it call) but if i move my car little bit, it start right up.
If I stall my car (new to stick shift) it have a hard time try to start again. (sometime crank sometime not) but even surly it will start.
Could it be that I need a new starter? or is it something else?
I just don't want to run out and get a new stater if that not the problem.
dsm=why walk the dog when you can walk your crank!
It could be quite a few other things but if it isn't cranking then it could be your starter.
