failed emissions - some DPFI questions (solved-bad cat)
                    My 90 failed TX emissions for high HC at idle only.
Any tips?
I'm going to change plugs and O2 sensor.
How many coolant temp sensors does a DPFI have? Just the one under the distributor? Does this run both the temp gauge and the EFI? I wonder if the car thinks it's cold so it fattens up the idle mixture.
Car seems to run great except it seems to run rich and miss some at idle - I hear the occasional "spit" while idling.
Is there a Honda FI troubleshooting site somewhere? I'm curious about things like:
- when does EFI go to closed loop
- what sensors are used and when and how and located
- when does DPFI use one injector or both
I'll take any suggestions
Thanks for your help
emissions numbers were:
At 800 RPM (idle?):
HC 401 actual 220 limit (fail)
CO 0.43% actual 1.20% limit (pass)
CO2 13.1% actual no limit specified
O2 1.7% actual no limit specified
Dilution 13.53 actual >6.0 required (pass)
At 2700 RPM:
HC 89 actual 220 limit (pass)
CO 0.67% actual 1.20% limit (pass)
CO2 13.3% actual no limit specified
O2 1.1% actual no limit specified
Dilution 14.17 actual >6.0 required (pass)
                            Any tips?
At 800 RPM (idle?):
At 2700 RPM:
Arrrgghh (running away) screaming to many standards and service limits
tip 1: move to another state
tip 2: change fuel to alcoholmix
tip 3: bribe : )
Serious, engine type series, milage etc ...
'spit' as in misfire ?
mileage as in valves ...
ignition misfire due to fouled spark plugs or a bad plug. by burned exhaust valves (check compression),
lean misfire (check for vacuum leaks, low fuel pressure or dirty injectors), rich fuel conditions
(fuel saturated carburetor floats, excessive fuel pressure, leaky injectors or a dead O2 sensor),
EGR valve stuck open, misadjusted carburetor idle mixture, misadjusted throttle body air/fuel mixture ... at this point
the screaming started ...
and dont forget : )
Car has about 155000 miles. I adjusted the valves about 100 miles ago while chasing other issues that turned out to be timing belt off a couple of teeth. All valves were very loose. All in spec now.
I also did a compression test and all cylinders were around 190 PSI. I was pleasantly surprised because it was overheating due to a stuck thermostat when I got it. I thought it would need a head gasket.
The exhaust system is a mess from the rear suspension back, but I have not been under the rest of the car so I'll put it on some stands and check.
The "spit" is a miss I believe - going after plugs today. No EGR on mine.
I'll update any progress - thanks again - JB
Running richcan cause ''some to LARGE amounts of HC''.
Missing causes LARGE mounts of HC.Plugs is a good place to start.Also clean the Cap & Rotor.
Find the cause of these probs.
Retarding Timing will reduce HC.Maybe you're running too much adv.
The other trick I use is to run up the front tyre pressure to 45PSI if TX is using the dyno smog test.This makes the engine work easier.Afterwards drop it back down.Also go drive on the highway to warm the CAT ,then leave your Wgn running @ the smog place to keep the CAT HOT.
- fixed radiator leak
- Seafoam in oil
- Seafoam in gas tank, burned through whole tank, now on fresh gas
- Seafoam through intake
- fresh plugs
- fresh O2
- oil & filter change
drove for an hour+ and did not shut off before the test
It actually failed worse...
So I changed the plug wires and intake air temp sensor. The IAT was melted but still had good resistance readings. I did not get it retested yet.
I was about ready to throw in the towel and take it to local Honda mechanic. Then I noticed the muffler rattles and is full of junk so I decided to pull the catalytic converter and see if it was dumping crap into the muffler - this is what I found...
I'm no expert, but I'm pretty sure this is bad. I'll get a new one put on and get the muffler replaced (because it's full of crap and a true hack install) and retest. If it doesn't pass after that, it's got to go to a pro - nothing else for me to repalce...
its nice to get demotivated and such once a while ...
but the winner never quits ...
different points of view
great story tho ... love drama me ...
Catalytic converter (standard for some type)
To stay effective, the converter must not be contaminated by leaded gasoline
The converter can be overheated and damaged if its fed too much
unburned fuel mixture form the engine
- Dont push or tow the car to start, start with jumper cables
- Dont switch off the engine while the engine is running above idle speed
The last part is from the owners manual
Personally i didnt know that ...
My Magnaflow direct fit catalytic converter arrived yesterday (2 days early from Parts America). I put it on last night. I had to shorten the springs on the spring mounts and enlarge the spring mount holes on the new converter slightly with a file.
Passed TX Smog inspection with flying colors. I think I'll take this converter off and save it for next year and put my, um, free flow stock converter back on.
At 892 RPM (idle?):
HC 10 actual 220 limit (pass)
CO 0.00% actual 1.20% limit (pass)
CO2 15.0% actual no limit specified
O2 0.3% actual no limit specified
Dilution 14.96 actual >6.0 required (pass)
At 2622 RPM:
HC 13 actual 220 limit (pass)
CO 0.01% actual 1.20% limit (pass)
CO2 14.8% actual no limit specified
Dilution 14.81actual >6.0 required (pass)
The numbers look to me like the converter is using the available oxygen to do the converting. It's VERY efficient.
I also had the muffler replaced since it was full of junk from the old converter and the mounting was so bad the tip melted my bumper.
