Noise with RT4WD drivetrain
                    I have a 1988 RT4WD wagon with the manual transmission. I recently reinstalled the rear motor mount bracket with no problems. I am now getting a loud noise that sounds like the drive shaft is being struck by a hammer. The noise occurs when the car is moving: running or not, in gear or not, at any speed, but only in 4WD. It only makes the noise once about every 500 feet traveled.  Is it possible that the motor mount bracket is not aligned properly (this motor mount is mounted directly to the transmission)? It wasn't making the noise prior to this, but I had gone a while driving it in 2WD.  Can anyone point me in the right direction here?
