engine swap
                    Well, My shuttle doesn't drive very well anymore, blown headgasket.
The original engine was a D16a6 (Rt4WD), but I have a D15B2 lying around that I could swap for a cheap solution.... But will it fit?
I guess the engine itself is no problem, electrical and all, transmission from RT4WD will bolt on I guess, but what about the driveshafts? I heard somewhere the intermediate shaft won't fit ? (d15b2 had two shafts of different lenght...)
What if I wont be able to bolt on the internediate shaft? Can I use the D15b2 shafts of unequal lenght on mu RT4WD transmission?
thanks!
thanks!
not too sure about the halfshafts though.
Anyone knows about de driveshafts?
You mean the engines you know of use a lot of oil right ?
Where exactly are you in the Netherlands. I know of a truck driver who is frequently in the UK and travels from Slovenia. He's taken back body parts (inc a repro mugen kit) for Hondas in the past.
Engine is a possibility...
I forgot. I've got a D16A6 sat in a shuttle I'm breaking with a friend.
