HELP!!! cars turns over but wont start
                    drove to work fine today. went out to go to lunch and it would not start. turns over continually but thats it. please help.
---also, dont know how pertinent this is but it has a d16y7 with the ecu and intake manifold (dpfi) off of the original engine---
when you put the key to "on" do you here a *click* under the dash when your engine check light turns off? if not then it means your Main Relay is ghey.
check that first. second, check your ECU for any codes that it might be blinking.
if its the main relay, try clicking your key on-off on-off on-off over and over again until you here it click, then try cranking your car. i had this problem and that helped a bit.
you might wanna check that..
i found this little bit i wrote on a different thread:
to check your ECU codes you have to:
dudee, i just had this problem.
check and make sure it's getting fuel, see if the ecu is throwing any codes
REMOVE YOUR DISTRUBUTER'S CAP AND MAKE SURE YOUR ROTOR IS BOLTED IN.
replace the dizzy cap and rotor, wires, plugs.
make sure it's getting spark, air and fuel.
compression check, if you can afford it
take it to a shop and have diognostics ran on it. (around 45 obo.)
