Help with Wobble on Pass Side RT4WD
Hello everyone,
I hate to make a separate thread about this but I am trying to diagnose what is wrong with my girlfriends RT4wd civic wagon. She has a vibration that seems to be coming out of the transmission on the passenger side. It only happens when you go around 55mph plus. I have changed wheels, and have put two new refurbed axles in and it continues to do the same thing. I have been told it might be a differential bearing. The axle almost looks like its out of round when its roating when you have the car up on jackstands. I thought it was the axle so I replaced it, twice with no help.
Anyone have any idea what it might be, I just dropped the engine in there and the last thing I want to do is take it back out.
Yeah thats what I did at my house. I jacked it up and put it on all 4 jackstands. Without the wheels on you can see the axle kind move in a way it shouldnt if that makes any sense. Like its not rotating 100% correctly. I took the axle out and the noise went away and you could see the inside of the tranny spinning with zero issues. Idk maybe it somehow still is the axle. IDK lol
Keep in mind that the inner joint will have an out of round path of rotation if operated at any sort of angle. I am lifted 2" and have an operation angle of about 12 degrees on the inner, you can see the halfshafts bump up and down three times per revolution. That is just how a tripod joint operates. The more angle the bigger the out of round the path becomes. So with the suspension at full droop the wobble as you put it will be VERY noticeable.
