Oil Leak From unknown area?!?
So a few weeks ago I replaced some O rings in my spark plug tubes of my 91 Civic Wagon which I thought was the problem with my leak.. Turns out it is not, although that needed to be done... Anyways it is leaking somewhere above the oil filter, so removed it and found this....
I believe this is the Oil Pressure switch if Im wrong correct me.. Is it possible this could be the cause of the leak? I couldnt find any other spots that looked like they could be leaking, but its hard to see in there... The oil is leaking very fast like all 3.8 quarts in less then a week, I havent drove it since I found out how much it was leaking.. Also it only leaks when the car is running... Any advice would be very helpful.. Thank you very much...
