turbo build assistance
I'm going to be rebuilding and boosting my wagon this year, and just wanted to see if I could get some assistance making sure I have a list of everything I will need for the build. My list so far is
-ebay turbo kit (may replace ebay turbo with a garrett)
-vitara pistons on stock rods (have read that will be fine for moderate boost)
-bigger injectors (not sure what size, only plan on running low boost, aiming for low to mid 200 whp)
-walbro 255
-valves, springs, seals, and guides from lowe mileage d16 head, stock a6 head and block machined
-obd1 ecu (not sure what kind I need, no vtec, so not sure of that makes a difference)
-obd0 to obd1 jumper harness
-ARP headstuds
-ARP wheel studs (have heard stockers don't hold up well to much more power)
-half radiator
Is there anything else I need to have or should get, this is my first time boosting a car, and my wagon is my main DD, so I will be wanting to get the rebuild and turbo build done fairly quick. Any help will be greatly appreciated, thanks!
-walbro 255
-ARP headstuds
-half radiator
Also, go P2P0 rods and pistons. You will hate how low the compression is on stock rods. Wouldn't really even need these for a 200hp build depending on turbo and boost.
Injectors, DSM 440's should be fine.
255 is fine
OEM head parts will be fine, and are cheap enough to not reuse.
ECU can be done through Phearable.net. Easiest route.
Jumper can also be had from Phearable or Rywire
Here is what I would do. Buy another car. Make the wagon a "project," but have another as a spare. Nothing sucks more than breaking your only car because you bought cheap parts, which leads me to part 2, buy quality. You're going boost. You should absolutely not skimp anywhere. It is a very different animal. That being said;
Find a spare D16Z6
P2P0 rods with 75.5mm pistons
OEM rebuilt head
Saturated precision 650's for room to grow
walboro 255
Good clutch
Go-Autoworks turbo kit
Honda-Tech.com has a boost section that has plenty of info to go from.
Thanks for the tips, as far as the turbo kit, I was thinking of buying an eBay kit, but getting a better turbo and manifold and selling the eBay ones. I guess I should have also mentioned that although the wagon is my main DD, I do have another car, just don't drive it quite as often since it gets a lot less mpg, so I am covered transportation wise if it takes longer than expected for the build.
A lot of people use eBay stuff and get away with it, but fwiw, I wouldn't. There are far more horror stories from them than there are good.
