damn (crank) bolt!!
                    i really hate crank pulley bolts.
well i was trying to do the timing belt, water pump, etc..
on my new motor but i couldn't get that bolt off.
hit it with an impact gun, pb blaster, and breaker bar.
i did get the tapped oil pan and gasket on so the day
wasn't a total waste. flywheel clutch kit and trans is next.
well that is if i can get thaT DAMN BOLT OFF!
repeat and wait.
Then zip it right off with 90 psi and a cheapy impact gun.
Honda's Zinc CAdium plating = best thread locker ever!
Makes it a cinch.
You need a heavy duty ratchet something like a 1/2" thick. The you get someone to step on the breaks as hard as they can. Then you put a 3foot cheater bar or somthing to extend your touque. The use your body weight to push down the it sould pop.
then two guys pushed down on the 3 ft breaker bar and then it came off.
Trying the timing belt/water pump job myself. My problem right now isn't the crank pulley bolt, but immobilizing the engine so that I can remove the bolt instead of turning the crank. Car is an automatic, so putting it into gear and having someone stand on the brake isn't an option (tried it anyway, didn't work). The Haynes book says to wedge a screwdriver into the teeth of the flywheel, but the automatic doesn't expose any teeth, and the book doesn't say how to do this on an auto. I'm truly lost, and the car is in pieces in my girlfriend's garage until I do something here. Any ideas? At all? Please???
Over here it's $70, over there I'd expect it to be 50%.
If it's the first one, just take a long piece of good iron, and weld 2 little pieces on it that fall into 2 opposite holes. Now you can block the pulley.
if it;'s the second one, get a huge nut with the same size, weld it on a long piece of iron, and it;s blocked.
in either case, you have to make sure that your newly made tool doesn't sit in the way for your tool to remove the crankpulley-bolt itself...
Good luck
I do have an impact wrench now. It's able to hammer away at the bolt without turning the crank. Yay!
Unfortunately, it's having no effect on the bolt whatsoever.
:evil:
