transmission swaps - manuals
Is there a link or guide that would tell one what swaps can be made?
I would like to know if a 1988 RT4WD manual could be changed out for a 1989 5 speed manual without any changes? Would the flywheel be the same? Cables/linkage? Gear shifter?
The 2wd trans is rod-shifted, the 4wd uses cables. You would have to cut a hole in the tunnel and install shifter from a 2wd car, after removing the RT shifter and cables.
Looks like I lied to you. I didn't take a photo of it at all. I'll see if I can find a diagram and point out the gear to you.
