Driveshaft Shop interest
So I noticed our basic option is U-Joint replacement. I emailed DSS and asked if they would consider making some sort of replacements for us and he seemed open to the idea. Only catch was they to have one to see what they can do and I have no spares. Anyone think they would be willing to send one to them? I'd even go as far to help on shipping to get something made entirely from such a reputable shop.
Hook me up?
My goal is as close to 100% as possible. I don't really want to have to just swap new U-Joints into an old shaft. I want to be able to order new parts entirely and swap them out, then maybe rebuild the old shafts for fun/spares. I also figured everyone else would like you have the luxury as well and more so backed by such a reputable company. Not saying rockford isn't, just personal preference.
thats the best i have.
How did that driveshaft work without the coupler? Did it affect anything poorly or did it work better?
Here are your dimensions as best I could measure, on a very quick sketch of the part (hard to measure hole centerline to centerline). I would say that it could be +/- ~0.5mm or so.
When I measured from the outermost edge of each bolt hole, and then subtracted the diameter of the holes (8mm), I was measuring 51.5 and 61.5mm as the centerline distances. But when I just eyeballed the center of each hole, I was getting 51 and 61mm.
Let me know if ya want any other dimensions...
I just got an 05 CR-V in at work, and it got my brain working. It's got an 81.5" 2 piece driveshaft, and the flanges look VERY similar. All we'd have to do is drill and tap for the carrier bearing if it fits, and voila! VC delete. I assume the rubber insulated carrier would help with driveline harshness these things have. The front flange, bolt center to bolt center is 1 7/8" by 2 1/8" and the rear is the same. (sorry, my tape measure is cheap and only has inches printed on it.)
Those bolt center to bolt center measurements are different from ours, which is about 2.4" by 2"
:c
I also am talking to a local drivetrain shop and they seem to claim they can find me everything I need, but I am not holding my breath. I'll keep trying!
rear is geared higher and drags until the front spins, this is fundamental in how RT4WD works to my understanding
