rt4wd Clutch Cable
Well, I've been screwing around trying to find a new clutch cable and I really can't seem to find any good answers. So, I started doing some digging based on this thread:
http://www.civicwagon.com/showthread.php?14205-rt4wd-clutch-cable-replacement-part-number&highlight=clutch+cable+replacement
So here's what I've tried so far:
1. OEM Clutch Cable for 88-91 civic, non-rt4wd: Too short by about 1"
2. Pioneer CA-506 cable: Too short by about 1"
Now I'm doing some digging. Here's a screenshot from Pioneer's catalog: As you can see there's 2 cables for an 88-91 rt4wd wagon (CA-506 and CA-507). The CA-507 is supposedly 61.5" long, but there is no length listed for the CA-507. I tried to call them directly and ask but there's no contact number, only contact via email that I could find.
Also, I looked up a Beck-Arnley part number (093-0602) that was mentioned in the thread above. Here's some info from their website:
1. Part number 093-0600: For fwd civic wagon, Length = 59.21"
2. Part number 093-0602: For rt4wd civic wagon, Length = 60.43"
So, this definitely leads me to believe that there IS actually a difference between the two clutch cables. Why the lengths between the Pioneer and Beck-Arnley parts are so different is beyond me. Maybe there's a difference in the length of the rubber housing that makes up for the difference.
Anyway, I am going to return the Pioneer CA-506 cable to Oreilley's and get them to order me the CA-507 cable, just to see if it works. If that doesn't work, I'm going to return it and order the Beck-Arnley 093-0602 cable.
That being said...the OEM clutch cable is definitely much better quality than any of the pioneer cables. I would imagine it will last a lot longer and experience less degradation over time, due to a plastic coating around the cable itself. I imagine it would operate smoother because of this as well, considering there's less friction between the rubber "housing" and the cable itself.
Once I put in a wagon pedal assembly, I was able to use a regular OEM EF civic clutch cable from Honda with no issues.
From what I've read and researched, it seems like a non-wagon pedal assembly will work in a FWD wagon, despite the possibility of some minor rubbing of the clutch pedal on the a/c ducts. However, you will run into issues of getting the clutch cable to fit if you use a non-wagon pedal assembly with an RT wagon.
So, overall there are two fixes I know of if you have an RT wagon with a non-wagon pedal assembly:
1) Get a wagon pedal assembly
2) Artificially shorten the rubber housing of a regular EF civic clutch cable by cutting it about 2-3 inches shorter. I used a dremel because the rubber housing actually has coiled metal in it. This will give you enough extra "length" outside of the housing to use the cable. I did this with an old clutch cable I had, and it mounted up fine, but it was ugly, introduced a weird angle to the cable (which I don't think would be a real problem)...so I decided to get the right pedal assembly. If you're in a pinch or something, you can go this route.
Cheers!
