Auto to Manual swap?
My wagon (Auto D15b2) is all I've ever wanted. But the more I think about it the more I'd like to 5-speed swap it. What all exactly would I need? The obvious would be Tranny, shift linkage, clutch assembly, ecu(?), but what about all the little things I would need? I'm trying to get a full list of parts that I'd need for the swap. Thanks in advance!
-Trans
-Clutch assembly/pedal assembly
-Shift Linkage
-ECU
-Passenger side trans mount bracket (the one that's actually welded to the frame)
-Front rear subframe
-Rear trans mount
I think that covers everything...if you're only wanting to do a FWD auto to manual swap, I know you don't have to worry about the passenger side trans mount. You might also not have to worry about the subframe and rear trans mount, but I'm not 100% sure on that part.
I used the pedal cluster off a 88 dx crx. Not to hard if you have the right tool and read up first.
I actually came across the 1" difference when doing a search on this forum: http://www.civicwagon.com/showthread.php?14205-rt4wd-clutch-cable-replacement-part-number&highlight=clutch+cable+replacement
Based on that thread it looks like "PIONEER Clutch/Cable CA-506" is gonna be the only available replacement. I just called O'reilleys and they can special order it. Their system will NOT tell them exactly what one you need though. Their computer brings up the CA-506 and the CA-507. I'm assuming the CA-507 is probably the 1" shorter cable.
Anyway I am going to go up there and pay for it so they'll order it for me. I'll report back on whether or not it works any better than the OEM fwd wagon cable. Hopefully there's no need to hoard!!
Good point, the load on the cable is likely low enough to where stretching due to fatigue stresses would not be an issue. On the OEM cable, the wire is sealed in a plastic sheathing (I'm interested to see if the aftermarket cable is the same style), so I doubt corrosion is too big of an issue until that sheathing gets worn away - at which point wear due to friction between the individual steel strands is probably another factor that could cause some stretch in the wire itself. Once the strands start to narrow due to abrasion, the wire as a whole will "settle" to a slightly narrower profile, causing some stretch.
But you're right, the housing likely compresses way more than the steel stretches in the normal life of the cable.
Well, I can confirm that that Pioneer part number CA-506 mentioned in the other thread DOES NOT work. It is the same length as the OEM fwd wagon cable, and seems to be about an inch short. I'm gonna return it to Oreilley's and try to get the CA-507 cable. Hopefully it will be the right length...
