axle pulled out, help?
So I was taking my shock/spring assembly out of my RT on the passenger side, the bolt on the fork got stuck so I decided to seperate the upper ball joint. But when i did this i pushed down too hard and pulled out the axle. now i cant get it back in or get the axle nut off. any ideas?
Make sure the axle is feeding into the trans straight, where the axle nut is make sure that is straight as well and and give it a whack with a rubber mallet. Should pop right in. Good luck!
