any shops that do the rear lsd? modded front 88-00 civic lsd into the rear of wagon?
so i picked up some spare parts for my wagon build and i was wondering who is experienced with swaping lsd from a 88-00 civic into the rear? i got another rear diff and a v/c. i was planing on welding the v/c but i decided not to. but i still want LSD. i read some info on here but i cant find any shops that have done this before.
i was going to do this myself but i figure ill leave it to a expert. unless i can drill the tapped holes with a hand drill.....
i need the lsd drilled out then installed into a rear diff.
also what bearings should i use? or will the fwd diff bearings work?
how much would this cost? not for materials but for machine time and labor?
+++SiWagon FYI: '88-91('96)JDM Wagon Options & PARTS.
Under LSD.
heres the quote i assume your talking about "All it took was to bore out the threaded ring gear bolt holes to blind holes, as the rear diff ring gear is threaded for the ring gear bolts as opposed to the diff being threaded"
